Zum Hauptinhalt wechseln
ZTE Lever Front Camera Replacement
Was du brauchst
  1. ZTE Lever Front Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Front Camera Replacement: Schritt 2, Bild 1 von 2 ZTE Lever Front Camera Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Front Camera Replacement: Schritt 3, Bild 1 von 2 ZTE Lever Front Camera Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Front Camera Replacement: Schritt 4, Bild 1 von 2 ZTE Lever Front Camera Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Front Camera Replacement: Schritt 5, Bild 1 von 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Front Camera Replacement, Front Camera: Schritt 6, Bild 1 von 2 ZTE Lever Front Camera Replacement, Front Camera: Schritt 6, Bild 2 von 2
    • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
    • Pry off the plastic cover using the iFixit opening tool.
  7. ZTE Lever Front Camera Replacement: Schritt 7, Bild 1 von 2 ZTE Lever Front Camera Replacement: Schritt 7, Bild 2 von 2
    • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
    • Remove the camera from the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 121
