Einleitung
This guide will demonstrate how to replace the front camera from the mother board of the ZTE Lever phone.
Was du brauchst
Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
Remove the cover.
Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
Pry off the plastic cover using the iFixit opening tool.
Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
Remove the camera from the motherboard.
