Einleitung
This guide will show you how to replace the loud speaker on a ZTE Lever smartphone.
  1. Remove the SD card and the Sim card from the device.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. Use an plastic opening tool to separate the back from the device.
    • Use an plastic opening tool to separate the back from the device.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
    • Remove the top plastic motherboard cover using a plastic opening tool.
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
    • Disconnect the power button from the motherboard with a plastic opening tool.
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
    • Remove the bottom plastic motherboard cover with your fingers
    • Disconnect the camera from the motherboard with a plastic opening tool.
    • Disconnect the display cable from the motherboard with a plastic opening tool.
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
    • Pry the motherboard cell battery from its position on the case of the phone
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
    • Remove the motherboard with your fingers.
    • Using the plastic opening tool, remove the speaker.
Abschluss
Luke Kilbourne
Mitglied seit 29.01.2018
291 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S5-G2, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 53
