Was du brauchst
Remove the back cover of your phone by placing your finger in the slot located on the back bottom left handed side of the phone.
Remove the battery.
Remove the 9 Phillips- Head screws with a Ph000 screwdriver
Using your pry tool, slide it along the edges of the phone closest to the screen. This releases the screen from the housing.
Use your pick to separate screen from the LCD and motherboard.
Replace old screen with new screen.
Before you put all necessary parts back on your device place the battery back in the slot it goes and power on your device. This ensures that your screen is working properly.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
