Zum Hauptinhalt wechseln
ZTE Maven 3 SIM Card Replacement
Was du brauchst
  1. ZTE Maven 3 SIM Card Replacement, Back Cover: Schritt 1, Bild 1 von 3 ZTE Maven 3 SIM Card Replacement, Back Cover: Schritt 1, Bild 2 von 3 ZTE Maven 3 SIM Card Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 SIM Card Replacement, SIM Card: Schritt 2, Bild 1 von 1
    • Locate the SIM Card slot on the upper left middle of the phone.
    • Remove the SIM card carefully from the back of the phone by gently sliding the card up and lifting it. Put the SIM to the side.
    • Gently pop in the new sim card where the old one was just removed.
Abschluss
Emma Thiboutot
699 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team 3-1, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 77
