Zum Hauptinhalt wechseln
ZTE Maven 3 Screen Replacement
Was du brauchst
  1. ZTE Maven 3 Screen Replacement, Back Cover: Schritt 1, Bild 1 von 3 ZTE Maven 3 Screen Replacement, Back Cover: Schritt 1, Bild 2 von 3 ZTE Maven 3 Screen Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Screen Replacement, Battery: Schritt 2, Bild 1 von 3 ZTE Maven 3 Screen Replacement, Battery: Schritt 2, Bild 2 von 3 ZTE Maven 3 Screen Replacement, Battery: Schritt 2, Bild 3 von 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Screen Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Screen Replacement: Schritt 4, Bild 1 von 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Screen Replacement: Schritt 5, Bild 1 von 2 ZTE Maven 3 Screen Replacement: Schritt 5, Bild 2 von 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Screen Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
  7. ZTE Maven 3 Screen Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
  8. ZTE Maven 3 Screen Replacement: Schritt 8, Bild 1 von 2 ZTE Maven 3 Screen Replacement: Schritt 8, Bild 2 von 2
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
  9. ZTE Maven 3 Screen Replacement: Schritt 9, Bild 1 von 3 ZTE Maven 3 Screen Replacement: Schritt 9, Bild 2 von 3 ZTE Maven 3 Screen Replacement: Schritt 9, Bild 3 von 3
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
  10. ZTE Maven 3 Screen Replacement: Schritt 10, Bild 1 von 2 ZTE Maven 3 Screen Replacement: Schritt 10, Bild 2 von 2
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
  11. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: Schritt 11, Bild 1 von 2 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: Schritt 11, Bild 2 von 2
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
  12. ZTE Maven 3 Screen Replacement, Screen: Schritt 12, Bild 1 von 1
    • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
Abschluss
Emma Thiboutot
699 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team 3-1, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 89
