Zum Hauptinhalt wechseln
ZTE Maven 3 Speaker Replacement
Was du brauchst
  1. ZTE Maven 3 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 3 ZTE Maven 3 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 3 ZTE Maven 3 Speaker Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Speaker Replacement, Battery: Schritt 2, Bild 1 von 3 ZTE Maven 3 Speaker Replacement, Battery: Schritt 2, Bild 2 von 3 ZTE Maven 3 Speaker Replacement, Battery: Schritt 2, Bild 3 von 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Speaker Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Speaker Replacement: Schritt 4, Bild 1 von 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Speaker Replacement: Schritt 5, Bild 1 von 2 ZTE Maven 3 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Speaker Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Put the midframe on its back and locate the speaker on the bottom left corner.
  7. ZTE Maven 3 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Gently lift the speaker out of the midframe using your fingers or a tool.
Abschluss
UMass Dartmouth, Team 3-1, Konn Fall 2023 Mitglied von UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 26
