Zum Hauptinhalt wechseln
ZTE Maven Motherboard Replacement
Was du brauchst
  1. ZTE Maven Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Maven Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the back cover.
  2. ZTE Maven Motherboard Replacement, SIM Card: Schritt 2, Bild 1 von 2 ZTE Maven Motherboard Replacement, SIM Card: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the SIM card from the right side of the device using a pair of tweezers.
  3. ZTE Maven Motherboard Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
  4. ZTE Maven Motherboard Replacement: Schritt 4, Bild 1 von 3 ZTE Maven Motherboard Replacement: Schritt 4, Bild 2 von 3 ZTE Maven Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
  5. ZTE Maven Motherboard Replacement, Front Camera: Schritt 5, Bild 1 von 3 ZTE Maven Motherboard Replacement, Front Camera: Schritt 5, Bild 2 von 3 ZTE Maven Motherboard Replacement, Front Camera: Schritt 5, Bild 3 von 3
    • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
    • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
  6. ZTE Maven Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 ZTE Maven Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 ZTE Maven Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Detach the clips and cables and carefully and pull the glue pieces off the sides.
    • Remove the motherboard with your fingers.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Is it possible to remove the wifi chip or component. From ZTE Z812 cell. And still be able to use it for talk and text. And if possible where is it located. And how, or where can I have it done, I'm in Houston, Texas. I know it's over kill but that's my question /comment. Thanks for your time.
Damon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 510
