Einleitung
This guide has step-by-step instructions on how to exit Field Test Mode on your ZTE Max XL. To determine if you are in Field Test Mode, refer to our Troubleshooting Guide.
Field Test Mode (FTM) can be useful if you perform tests on signal strength, but for most users it prevents some applications to run correctly.
The phone screen will display FTM when in the mode.
If the phone is still in FTM after the reboot, make sure the lower volume button is not stuck.
After the button is unstuck, repeat step three.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
