Einleitung
Removing the cameras of the ZTE Speed is a very simple process, proceed below!
Was du brauchst
Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
With the plastic opening tool the spudger, gently pry off the inner back seal around the phone.
Be careful not to pry it off too harsh, as it is just plastic.
With the spudger, gently pry off camera at the top-middle of the phone to get back camera.
With the spudger, gently pry off camera at the top-left of the phone to get the front camera.
3 weitere Personen haben diese Anleitung absolviert.
