Zum Hauptinhalt wechseln
ZTE Speed Headphone Jack Replacement
Was du brauchst
  1. ZTE Speed Headphone Jack Replacement, Motherboard: Schritt 1, Bild 1 von 2 ZTE Speed Headphone Jack Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Headphone Jack Replacement: Schritt 2, Bild 1 von 2 ZTE Speed Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Headphone Jack Replacement: Schritt 3, Bild 1 von 2 ZTE Speed Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Headphone Jack Replacement: Schritt 5, Bild 1 von 3 ZTE Speed Headphone Jack Replacement: Schritt 5, Bild 2 von 3 ZTE Speed Headphone Jack Replacement: Schritt 5, Bild 3 von 3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Headphone Jack Replacement: Schritt 6, Bild 1 von 2 ZTE Speed Headphone Jack Replacement: Schritt 6, Bild 2 von 2
    • Carefully take off motherboard.
  7. ZTE Speed Headphone Jack Replacement, Headphone Jack: Schritt 7, Bild 1 von 2 ZTE Speed Headphone Jack Replacement, Headphone Jack: Schritt 7, Bild 2 von 2
    • Flip over motherboard to locate headphone jack circuit.
Abschluss
Garrett Barry
722 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 240
