Einleitung
Replace the battery on your ZTE Telstra T95 in three easy steps. No background information necessary.
Was du brauchst
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
The battery snaps out of place and you can remove it using your fingers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
