Einleitung
In this guide you will learn how to replace your SIM card. If your current SIM card is not functioning contact your service cellphone service provider to receive a replacement.
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
The battery snaps out of place and you can remove it using your fingers.
Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
2 weitere Personen haben diese Anleitung absolviert.
