Zum Hauptinhalt wechseln
Einleitung
If the battery dies quickly, this replacement guide should help to make it function.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a plastic opening tool to pry open the back case. Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable. Lift the battery up and remove it from the phone. Lift the battery up and remove it from the phone.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
omar
717 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 177
