Zum Hauptinhalt wechseln
Einleitung
If the back camera is showing a black screen or the camera does not take a picture.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Pry open the back case to get to the back cover. Remove eight 5mm screws with a PH0 screw.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  3. Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable. Lift the rear camera out of the phone.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
omar
717 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 105
