Zum Hauptinhalt wechseln
ZTE Tempo X Charging/Aux Board Replacement
Was du brauchst
  1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Tempo X Charging/Aux Board Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Charging/Aux Board Replacement, Battery: Schritt 2, Bild 1 von 2 ZTE Tempo X Charging/Aux Board Replacement, Battery: Schritt 2, Bild 2 von 2
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: Schritt 3, Bild 1 von 2 ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: Schritt 3, Bild 2 von 2
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  4. ZTE Tempo X Charging/Aux Board Replacement: Schritt 4, Bild 1 von 2 ZTE Tempo X Charging/Aux Board Replacement: Schritt 4, Bild 2 von 2
    • Take off the second back cover, lifting from the bottom of the device to the top.
  5. ZTE Tempo X Charging/Aux Board Replacement: Schritt 5, Bild 1 von 3 ZTE Tempo X Charging/Aux Board Replacement: Schritt 5, Bild 2 von 3 ZTE Tempo X Charging/Aux Board Replacement: Schritt 5, Bild 3 von 3
    • Using a spudger, unclip the board from the phone at the places highlighted.
  6. ZTE Tempo X Charging/Aux Board Replacement: Schritt 6, Bild 1 von 3 ZTE Tempo X Charging/Aux Board Replacement: Schritt 6, Bild 2 von 3 ZTE Tempo X Charging/Aux Board Replacement: Schritt 6, Bild 3 von 3
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
Abschluss
Conager Robb
592 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 233
