Einleitung
In the event that your ZTE Tempo X is having trouble taking photos, use this guide to replace the front facing camera.
Was du brauchst
Find the divot near the bottom of the battery and remove the battery from the device.
Remove the sixteen 3 mm screws on the back cover of the phone using the Phillips #000 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using the spudger, detach the brown flap by flipping it towards you.
With a fine pair of tweezers, pull the front facing camera from the phone.
