Zum Hauptinhalt wechseln
ZTE Whirl 2 Camera Replacement
Was du brauchst
  1. ZTE Whirl 2 Camera Replacement, Battery: Schritt 1, Bild 1 von 3 ZTE Whirl 2 Camera Replacement, Battery: Schritt 1, Bild 2 von 3 ZTE Whirl 2 Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. ZTE Whirl 2 Camera Replacement: Schritt 2, Bild 1 von 3 ZTE Whirl 2 Camera Replacement: Schritt 2, Bild 2 von 3 ZTE Whirl 2 Camera Replacement: Schritt 2, Bild 3 von 3
    • Pry the battery from the phone using your fingers.
  3. ZTE Whirl 2 Camera Replacement, Back Panel: Schritt 3, Bild 1 von 3 ZTE Whirl 2 Camera Replacement, Back Panel: Schritt 3, Bild 2 von 3 ZTE Whirl 2 Camera Replacement, Back Panel: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. ZTE Whirl 2 Camera Replacement: Schritt 4, Bild 1 von 3 ZTE Whirl 2 Camera Replacement: Schritt 4, Bild 2 von 3 ZTE Whirl 2 Camera Replacement: Schritt 4, Bild 3 von 3
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. ZTE Whirl 2 Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the midframe from the digitizer.
  6. ZTE Whirl 2 Camera Replacement, Camera: Schritt 6, Bild 1 von 3 ZTE Whirl 2 Camera Replacement, Camera: Schritt 6, Bild 2 von 3 ZTE Whirl 2 Camera Replacement, Camera: Schritt 6, Bild 3 von 3
    • Use the iFixit Opening Tool to disconnect the camera connector by prying up the press fit connector from the motherboard.
    • Remove the camera from the device.
Abschluss
Alana Rucks
461 Reputation
4 Anleitungen geschrieben
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G1, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 93
