Einleitung
This guide provides the steps necessary to replace the front-facing camera on the ZTE ZFive G LTE.
Was du brauchst
Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
Once the body is removed, you will see the front facing camera at the top right corner of the device.
Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Using angled tweezers, gently pull the ribbon wire up from the body.
Eine weitere Person hat diese Anleitung absolviert.
