Einleitung
This is not a guide for replacing the switch assembly, only for replacing the plastic covers to the buttons.
Was du brauchst
Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
Being careful with the device, gently pull up the device body tugging from the inside of the device.
Be sure to pull away from the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Eine weitere Person hat diese Anleitung absolviert.
