Zum Hauptinhalt wechseln
ZTE ZFive G LTE Volume and Power Button Replacement
Was du brauchst
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: Schritt 1, Bild 1 von 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: Schritt 1, Bild 2 von 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: Schritt 1, Bild 3 von 3
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 2, Bild 1 von 2 ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 3, Bild 1 von 2 ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 3, Bild 2 von 2
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 4, Bild 1 von 2 ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 4, Bild 2 von 2
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 5, Bild 1 von 2 ZTE ZFive G LTE Volume and Power Button Replacement: Schritt 5, Bild 2 von 2
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 315
