Zum Hauptinhalt wechseln
ZTE ZMAX Z970 Battery Replacement
Was du brauchst
  1. ZTE ZMAX Z970  Battery Replacement, Battery: Schritt 1, Bild 1 von 2 ZTE ZMAX Z970  Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970  Battery Replacement: Schritt 2, Bild 1 von 2 ZTE ZMAX Z970  Battery Replacement: Schritt 2, Bild 2 von 2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970  Battery Replacement: Schritt 3, Bild 1 von 3 ZTE ZMAX Z970  Battery Replacement: Schritt 3, Bild 2 von 3 ZTE ZMAX Z970  Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970  Battery Replacement: Schritt 4, Bild 1 von 2 ZTE ZMAX Z970  Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970  Battery Replacement: Schritt 5, Bild 1 von 2 ZTE ZMAX Z970  Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970  Battery Replacement: Schritt 6, Bild 1 von 2 ZTE ZMAX Z970  Battery Replacement: Schritt 6, Bild 2 von 2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Burak Cengiz
480 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S17-G3, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Although I haven’t yet embarked on this task, I feel more confident in doing so successfully. I have watched the Youtube videos on this and none of them showed such things as the number and placement of the screws. They did give some idea as to the difficulty of it however.
Please continue to produce more of these instructional blurbs.
aikidoronin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,703
