Einleitung
This guide will show you how to replace the rear camera on your ZTE ZMAX Z970 smartphone.
Was du brauchst
Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
Pull out the trays.
Insert a plastic opening tool into the groove between the phone’s back cover and casing.
Move the plastic opening tool along the edges of the phone to unclip the two pieces.
Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
Once free from the glue, remove from device.
Disconnect the camera from the motherboard with the flat end of a spudger.
Remove carefully with tweezers.
