Einleitung
A guide on the replacement of the volume buttons on a ZTE ZMAX Z970 smartphone.
  1. Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
    • Remove the mid frame with the plastic opening tool.
    • Disconnect the battery from the motherboard.
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
    • Peel off circuit board carefully.
    • The new part will need to be soldered onto the motherboard.
Abschluss
Burak Cengiz
Mitglied seit 15.02.2018
480 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S17-G3, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 106
