Zum Hauptinhalt wechseln
ZTE ZMax Pro Back Panel Assembly Replacement
Was du brauchst
  1. ZTE ZMax Pro Back Panel Assembly Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
    Frag FixBot
  2. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 2, Bild 1 von 1
    • Using your fingers, slide the SIM card all the way out of the phone.
    Frag FixBot
  3. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 3, Bild 1 von 2 ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
    Frag FixBot
  4. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
    Frag FixBot
  5. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
    Frag FixBot
  6. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 6, Bild 1 von 2 ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 6, Bild 2 von 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
    Frag FixBot
  7. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
    Frag FixBot
  8. ZTE ZMax Pro Back Panel Assembly Replacement: Schritt 8, Bild 1 von 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S17-G3, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Mitglieder
16 Anleitungen geschrieben
1 Kommentar zur Anleitung
When I tried this at step 8 the screen peeled off instead of the top cover. Ruined my phone.
Solomon Martinez - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 90
Insgesamt: 1,268
