Einleitung
No button response or viewfinder image in your Zeal Optics iON goggles? Use this guide to replace a faulty button board, which also connects to the viewfinder lens assembly.
Was du brauchst
Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
Pull the rubber housing apart to release the first two clips.
Grab the inside of the plastic nose rest with your thumb and index finger.
Rotate the nose rest upwards until you feel that it is free from the lens.
Grab the top of the goggle frame that holds the camera assembly.
Rotate the frame outwards until you feel that the clips inside it are free.
While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Peel back the rubber battery cover from the inner left side of the frame.
While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
Peel the rubber keypad cover up from the inner right side of the frame.
While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
Place one of your hands near the center of the frame with your thumb next to the camera housing.
With your other hand, grab the camera housing and pull it up and out of the frame.
Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
Use the tip of a spudger to flip up the retaining flap on the button board data cable ZIF connector.
Remove the three 4.5 mm Phillips screws securing the button board to the viewfinder housing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
