Zum Hauptinhalt wechseln
Zebra ZP 450 Motherboard Replacement
Was du brauchst
  1. Zebra ZP 450 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Motherboard Replacement: Schritt 4, Bild 1 von 3 Zebra ZP 450 Motherboard Replacement: Schritt 4, Bild 2 von 3 Zebra ZP 450 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 435
