Zum Hauptinhalt wechseln
Zebra ZP 450 Power Cord Replacement
Was du brauchst
  1. Zebra ZP 450 Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
  2. Zebra ZP 450 Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Using the iFixit opening pick, remove the plastic cover.
  3. Zebra ZP 450 Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the single 14 mm screw from the clamp that is holding the power cord.
    • Remove the power cord from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 188
