Zum Hauptinhalt wechseln
Zeepad 7.0 Screen Replacement
Was du brauchst
  1. Zeepad 7.0 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Zeepad 7.0 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: Schritt 3, Bild 1 von 2 Zeepad 7.0 Screen Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: Schritt 4, Bild 1 von 1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: Schritt 5, Bild 1 von 2 Zeepad 7.0 Screen Replacement: Schritt 5, Bild 2 von 2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: Schritt 6, Bild 1 von 3 Zeepad 7.0 Screen Replacement: Schritt 6, Bild 2 von 3 Zeepad 7.0 Screen Replacement: Schritt 6, Bild 3 von 3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: Schritt 7, Bild 1 von 3 Zeepad 7.0 Screen Replacement: Schritt 7, Bild 2 von 3 Zeepad 7.0 Screen Replacement: Schritt 7, Bild 3 von 3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • Wie man Lötverbindungen herstellt und entlötet
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
Abschluss
To reassemble your device, follow these instructions in order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S2-G1, Harley Spring 2018 Mitglied von IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
where do you buy the screen?
Zuzzi Z Amend - Antwort
i need a battery an a screen? is their a place on this page where to get them?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 461
