Einleitung
This guide is going to explain the process of deconstruction of the Zeepad 7DRK and eventual removal of the device's battery for easy replacement.
Was du brauchst
Begin the process by prying off the back of the Zeepad using the opening tool.
Start by edging the corner of the opening tool into the edge of the device and work your way from there until the back cover is removed.
Once the back casing has been removed, identify the location of the battery inside the device, marked with the red circle.
Identify the pieces of tape holding the battery to the back of the screen, and peel them off to remove them.
Locate the connection between the battery and motherboard, and disconnect it by pulling the two apart.
To finally finish removing the battery, the two wires connecting to it must be separated.
Peel back the tape covering the origin of the wires.
Finally, remove the two metal connectors attached to the green piece from the battery with a tug.
The battery has now been successfully removed.
