Zum Hauptinhalt wechseln
Zeepad 7DRK Power and Volume Button Replacement
Was du brauchst
  1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: Schritt 1, Bild 1 von 1
    • First find the power and volume buttons so that you are familiar with their location.
    • The smaller button is the power button and the larger button is the volume button.
  2. Zeepad 7DRK Power and Volume Button  Replacement: Schritt 2, Bild 1 von 2 Zeepad 7DRK Power and Volume Button  Replacement: Schritt 2, Bild 2 von 2
    • To open the tablet, use one of the soft-tip prying tools.
    • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
  3. Zeepad 7DRK Power and Volume Button  Replacement: Schritt 3, Bild 1 von 1
    • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
    • This is what the tablet looks like when pried apart.
  4. Zeepad 7DRK Power and Volume Button  Replacement: Schritt 4, Bild 1 von 2 Zeepad 7DRK Power and Volume Button  Replacement: Schritt 4, Bild 2 von 2
    • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
    • In the second picture, the volume control button is shown. Again notice the small locator rings.
  5. Zeepad 7DRK Power and Volume Button  Replacement: Schritt 5, Bild 1 von 2 Zeepad 7DRK Power and Volume Button  Replacement: Schritt 5, Bild 2 von 2
    • Now remove the old or broken buttons, and replace them.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Trevor Taylor
234 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 6-8, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 336
