Einleitung
This guide is going to explain how to take the device apart to remove the speaker for eventual replacement.
Was du brauchst
Begin by popping off the plastic yellow device casing with the soft tip prying tool.
Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
Once the device is opened, the speaker should fall out of its position.
Follow the red and black wires attached to the speaker to find the location of connection.
The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
