Einleitung
This guide will begin with the disassembly of the Zeki Droid tablet. Throughout the replacement process be cautious in order to not break any pieces on the device. The replacement should only take about ten to fifteen minutes.
Was du brauchst
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Remove the black clips from both sides of the casing with a plastic opening tool.
Fast fertig!
Abschluss
