Zum Hauptinhalt wechseln
Zeki Droid Tablet Battery Replacement
Was du brauchst
  1. Zeki Droid Tablet Battery Replacement, Back Casing: Schritt 1, Bild 1 von 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Battery Replacement: Schritt 5, Bild 1 von 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Battery Replacement, Battery: Schritt 6, Bild 1 von 1
    • To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
    • Do not bend the battery.
  7. Zeki Droid Tablet Battery Replacement: Schritt 7, Bild 1 von 1
    • To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
    • Using a soldering tool, you will desolder the tabs from the circuit board.
    • Please refer to the Wie man Lötverbindungen herstellt und entlötet
    • If your replacement battery already has the small circuit board attached, you can desolder the red and black wires connected to the mother board instead of the metal tabs.
  8. Zeki Droid Tablet Battery Replacement: Schritt 8, Bild 1 von 1
    • To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
    • Please refer to Wie man Lötverbindungen herstellt und entlötet
    • If you have the battery with the circuit board connected, then you can solder the red and black wires back to the mother board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kyla
156 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 2-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
3 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
will this be the same for a tbqc 1065b?
mark campbell - Antwort
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
CIaudia Bringe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 5,462
