Zum Hauptinhalt wechseln
Zeki Droid Tablet Camera Replacement
Was du brauchst
  1. Zeki Droid Tablet Camera Replacement, Back Casing: Schritt 1, Bild 1 von 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Camera Replacement: Schritt 3, Bild 1 von 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Camera Replacement: Schritt 5, Bild 1 von 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Camera Replacement, Camera: Schritt 6, Bild 1 von 2 Zeki Droid Tablet Camera Replacement, Camera: Schritt 6, Bild 2 von 2
    • Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
    • The adhesive may make it difficult to remove the cameras from the tablet.
  7. Zeki Droid Tablet Camera Replacement: Schritt 7, Bild 1 von 1
    • Undo the ZIF connector that is connecting the cameras to the motherboard using a plastic spudger or fingernail.
    • This guide has more information on how to undo the ZIF connector
    • Do not yank the ZIF connector. It should come apart very easily with little force needed.
  8. Zeki Droid Tablet Camera Replacement: Schritt 8, Bild 1 von 1
    • Pull the copper connection carefully away from the motherboard of the tablet to completely remove the camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Colorado Springs, Team 2-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 375
