Zum Hauptinhalt wechseln
Zeki TBQG884B Rear Case Replacement
Was du brauchst
  1. Zeki TBQG884B Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 2 Zeki TBQG884B Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Rear Case Replacement: Schritt 2, Bild 1 von 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Rear Case Replacement: Schritt 3, Bild 1 von 2 Zeki TBQG884B Rear Case Replacement: Schritt 3, Bild 2 von 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
Abschluss
David Wyman
343 Reputation
3 Anleitungen geschrieben
IUPUI, Team 1-3, Harley Fall 2015 Mitglied von IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 359
