Einleitung
Before you begin this guide, make sure to have the proper tools. You will need a spudger, and a phillips head #00 screwdriver. If you're having trouble with the battery in your device, removing the back panel is one of the first steps in replacing the battery.
Was du brauchst
Remove the two screws on the bottom using a Phillips #00 screwdriver.
Using a spudger, start prying the case apart by working around the edge slowly.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
