Einleitung
This camera replacement guide should only be done once the prerequisite steps have been fully completed. Skipping any steps can lead to damage to your device.
Was du brauchst
Remove the two screws on the bottom using a Phillips #00 screwdriver.
Using a spudger, start prying the case apart by working around the edge slowly.
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
Slide back the plastic latch for the main display cable.
Carefully unplug the cable with tweezers.
Slide back the plastic latch for the camera cable.
Peel back the adhesive tape holding the camera in place.
Remove the camera from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
