Einleitung
Be sure to follow the prerequisite guides before removing the front panel. Skipping any of the guides can lead to damage to your device.
Was du brauchst
Remove the two screws on the bottom using a Phillips #00 screwdriver.
Using a spudger, start prying the case apart by working around the edge slowly.
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
Slide back the plastic latch for the camera cable.
Carefully unplug the cable with tweezers.
Remove the four highlighted screws using a Phillips #1 screwdriver.
Starting from the top, slowly lift everything up out of the front panel.
Remove the front panel off of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
