Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Be sure to follow the prerequisite guides before removing the front panel. Skipping any of the guides can lead to damage to your device.
  1. Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Using a spudger, start prying the case apart by working around the edge slowly. Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger. While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Flip up the small gate and unplug the ribbon cable shown.
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  6. Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  7. Slide back the plastic latch for the main display cable.
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  8. Slide back the plastic latch for the camera cable. Carefully unplug the cable with tweezers.
    • Slide back the plastic latch for the camera cable.
  9. Peel back the reflective tape.
    • Peel back the reflective tape.
  10. Lift up the motherboard assembly, starting by lifting up the top. Be careful not to damage any of the ports on the underside of the tablet.
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  11. Remove the four highlighted screws using a Phillips #1 screwdriver.
    • Remove the four highlighted screws using a Phillips #1 screwdriver.
    • For differentiation purposes, these screws are 4mm long and have a larger head than the rest of the screws.
  12. Starting from the top, slowly lift everything up out of the front panel.
    • Starting from the top, slowly lift everything up out of the front panel.
    • Remove the front panel off of the device.
    • Be careful not to damage the ports along the bottom.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Keelie Beach
414 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 76
