Zum Hauptinhalt wechseln
Zippo Lighter Felt Pad and Cotton Replacement
Was du brauchst
  1. Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: Schritt 1, Bild 1 von 3 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: Schritt 1, Bild 2 von 3 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: Schritt 1, Bild 3 von 3
    • Open the lid of the lighter.
    • Hold the bottom of the lighter’s case and pull out the metal container.
    • Set the case aside for now.
  2. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 2, Bild 1 von 2 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 2, Bild 2 von 2
    • Turn the metal container upside down with the bottom facing you.
    • You should see a piece of white felt with the words “Lift to fill.”
  3. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 3, Bild 1 von 2 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 3, Bild 2 von 2
    • Loosen the screw with a flathead screwdriver.
    • There is a spring behind the screw, so make sure you are unscrewing slowly and gently.
    • Remove the screw with the spring and the flint attached to it.
  4. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 4, Bild 1 von 2 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift the felt pad up and out of the metal container using a pair of tweezers.
  5. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 5, Bild 1 von 2 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 5, Bild 2 von 2
    • Use a pair of tweezers to remove the old cotton from the inside.
    • When adding new cotton, it should fully cover the inside of the metal canister.
    • Throw the old felt and cotton in the garbage.
  6. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 6, Bild 1 von 3 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 6, Bild 2 von 3 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 6, Bild 3 von 3
    • Use a pair of tweezers to push each cotton piece on top of the wick inside the metal container. Make sure the cotton pieces cover all the sides.
  7. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 7, Bild 1 von 1
    • Use a pair of tweezers to place the new felt pad on top of the cotton pieces.
  8. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 8, Bild 1 von 2 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 8, Bild 2 von 2
    • Replace the flint and screw it back into place using a flathead screwdriver.
  9. Zippo Lighter Felt Pad and Cotton Replacement: Schritt 9, Bild 1 von 2 Zippo Lighter Felt Pad and Cotton Replacement: Schritt 9, Bild 2 von 2
    • Refuel your lighter, put the metal container back inside the case, and test out the lighter.
    • Only use the lighter when it is secured inside the case.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dara
193 Reputation
1 Anleitung geschrieben
York University, Team G-35, O'Regan Fall 2021 Mitglied von York University, Team G-35, O'Regan Fall 2021
YORK-O'REGAN-F21SGG35
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 41
Letzte 30 Tage: 211
Insgesamt: 8,746
