Einleitung
This guide will show you how to replace the felt pad and cotton inside any model of a Zippo lighter. Use this guide when you feel like your lighter has shorter fuel life than it had before. Replacing the cotton and the felt pad helps with evaporation and fuel flow, and it provides a longer fuel life. Try to replace the cotton every four months if you use your Zippo as your daily lighter.
Before getting started, purchase a felt pad and cotton pack originally made by Zippo.
If you have fueled your lighter with lighter fluid recently, do not use your lighter for a week and let the cotton absorb all the fuel. Therefore, when you want to do the replacement it will be dry.
Was du brauchst
Open the lid of the lighter.
Hold the bottom of the lighter’s case and pull out the metal container.
Set the case aside for now.
Loosen the screw with a flathead screwdriver.
Remove the screw with the spring and the flint attached to it.
Lift the felt pad up and out of the metal container using a pair of tweezers.
Use a pair of tweezers to remove the old cotton from the inside.
Throw the old felt and cotton in the garbage.
Use a pair of tweezers to push each cotton piece on top of the wick inside the metal container. Make sure the cotton pieces cover all the sides.
Refuel your lighter, put the metal container back inside the case, and test out the lighter.
Eine weitere Person hat diese Anleitung absolviert.
