Zum Hauptinhalt wechseln
Zoom H1 Handy Recorder Battery Terminal Replacement
Was du brauchst
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: Schritt 1, Bild 1 von 1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 4, Bild 1 von 1
    • Carefully pry up the top end of the back cover using one finger
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 5, Bild 1 von 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 6, Bild 1 von 1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 7, Bild 1 von 1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 8, Bild 1 von 2 Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 8, Bild 2 von 2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 9, Bild 1 von 1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: Schritt 10, Bild 1 von 1
    • Place second lead at point 2 and re-solder.
Abschluss
To Re-construct device, perform these steps in reverse order.
Alex
809 Reputation
5 Anleitungen geschrieben
7 Kommentare
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Antwort
Mine has third screw under the serial-number sticker.
halluciana - Antwort
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Antwort
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Antwort
Same problem, without any reason it is dead
eevilcute -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 38
Insgesamt: 6,405
