Zum Hauptinhalt wechseln
Zoom H6 Handy Recorder Case Replacement
Was du brauchst
  1. Zoom H6 Handy Recorder Case Replacement, Case: Schritt 1, Bild 1 von 3 Zoom H6 Handy Recorder Case Replacement, Case: Schritt 1, Bild 2 von 3 Zoom H6 Handy Recorder Case Replacement, Case: Schritt 1, Bild 3 von 3
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Case Replacement: Schritt 2, Bild 1 von 3 Zoom H6 Handy Recorder Case Replacement: Schritt 2, Bild 2 von 3 Zoom H6 Handy Recorder Case Replacement: Schritt 2, Bild 3 von 3
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Case Replacement: Schritt 3, Bild 1 von 2 Zoom H6 Handy Recorder Case Replacement: Schritt 3, Bild 2 von 2
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Case Replacement: Schritt 4, Bild 1 von 3 Zoom H6 Handy Recorder Case Replacement: Schritt 4, Bild 2 von 3 Zoom H6 Handy Recorder Case Replacement: Schritt 4, Bild 3 von 3
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Rachel Calder
1.189 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S5-G2, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S5G2
4 Mitglieder
10 Anleitungen geschrieben
7 Kommentare
Where can I get the replacement part. I need to change the casing of my h6 and the power button
Dray - Antwort
Did you get to find the replacement casing? Where did you find it?
Jason Irving -
I need a case replacement, too. There is so much broken, hardly to fix with glue …
anything?
Michael Gasperl - Antwort
Has anybody found a source for Zoom parts? I would sure like to fix my UAC-8, but parts don’t seem to be available anywhere. It is kind of frustrating, the fix would be easy as heck, but not without parts.
Tim Andre - Antwort
contact your nearest dealer listed on the zoom website to buy a replacement set. They shipped me one after the cover finish turned ‘sticky’ and the battery plate lock mechanism broke off due to the plastic going bad. this can happen i.e. after you leave it the sun for too long, which happened to me. this tutorial doesn’t cover the bottom case which is more involving with all the electronics.
veto88 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 67
Insgesamt: 4,721
