Zum Hauptinhalt wechseln
Zoom H6 Handy Recorder Mic Connector Replacement
Was du brauchst
  1. Zoom H6 Handy Recorder Mic Connector Replacement, Case: Schritt 1, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement, Case: Schritt 1, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement, Case: Schritt 1, Bild 3 von 3
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 2, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 2, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 2, Bild 3 von 3
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 3, Bild 1 von 2 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 3, Bild 2 von 2
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 4, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 4, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 4, Bild 3 von 3
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
  5. Zoom H6 Handy Recorder Mic Connector Replacement, Motherboard: Schritt 5, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement, Motherboard: Schritt 5, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
  6. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 6, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 6, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 6, Bild 3 von 3
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
    • Set the button board aside.
  7. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 7, Bild 1 von 1
    • Unscrew four (PH #1), 8mm screws from the motherboard.
  8. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 8, Bild 1 von 1
    • Disconnect wire from motherboard using tweezers.
    • Do not touch the motherboard with metal tweezers. Only touch the plastic part of the plugged-in wire.
  9. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 9, Bild 1 von 1
    • Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
  10. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 10, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 10, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 10, Bild 3 von 3
    • Gently remove three ribbon connectors from the device.
    • The first is connected to the mic connector.
    • The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
    • It's best to use tweezers to remove the two ribbon connectors behind the display.
    • Avoid touching anything but the ribbon connectors with the metal tweezers.
  11. Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 11, Bild 1 von 2 Zoom H6 Handy Recorder Mic Connector Replacement: Schritt 11, Bild 2 von 2
    • Gently lift the motherboard from the base of the device and set aside.
  12. Zoom H6 Handy Recorder Mic Connector Replacement, Mic Connector: Schritt 12, Bild 1 von 3 Zoom H6 Handy Recorder Mic Connector Replacement, Mic Connector: Schritt 12, Bild 2 von 3 Zoom H6 Handy Recorder Mic Connector Replacement, Mic Connector: Schritt 12, Bild 3 von 3
    • Lift the mic connector from the base of the device and replace with a new component.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rachel Calder
1.189 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S5-G2, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S5G2
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Hi, Where can I find the part for the Zoom H6 Connector Replacement?
Jorgefilm - Antwort
It was an excellent tutorial
Jorgefilm - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,394
