Zum Hauptinhalt wechseln
Zoomer Dino Boomer Back Button Replacement
Was du brauchst
  1. Zoomer Dino Boomer Back Button Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Back Button Replacement: Schritt 2, Bild 1 von 2 Zoomer Dino Boomer Back Button Replacement: Schritt 2, Bild 2 von 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Back Button Replacement: Schritt 3, Bild 1 von 3 Zoomer Dino Boomer Back Button Replacement: Schritt 3, Bild 2 von 3 Zoomer Dino Boomer Back Button Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Back Button Replacement, Back Button: Schritt 4, Bild 1 von 1
    • Where the button is largest, squeeze the two white tabs together.
  5. Zoomer Dino Boomer Back Button Replacement: Schritt 5, Bild 1 von 1
    • Push in the white circular piece between these tabs as far as it will go.
  6. Zoomer Dino Boomer Back Button Replacement: Schritt 6, Bild 1 von 2 Zoomer Dino Boomer Back Button Replacement: Schritt 6, Bild 2 von 2
    • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
    • Remove the back button.
Abschluss
Lauren Mannix
392 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 16-1, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 12
Insgesamt: 1,887
