Zum Hauptinhalt wechseln
Zoomer Jurassic World Indominus Rex Back Cover Replacement
Was du brauchst
  1. Zoomer Jurassic World Indominus Rex Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Back Cover Replacement: Schritt 2, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Back Cover Replacement: Schritt 3, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
Abschluss
Anh Le
504 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 10-3, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 411
