Zum Hauptinhalt wechseln
Zoomer Jurassic World Indominus Rex Mouth Gears Replacement
Was du brauchst
  1. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: Schritt 1, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Part: Schritt 1, Bild 2 von 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 2, Bild 1 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 2, Bild 2 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 2, Bild 3 von 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: Schritt 3, Bild 1 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: Schritt 3, Bild 2 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement, Mouth Gears: Schritt 3, Bild 3 von 3
    • After removing the tongue, inspect and remove any debris from the inside of the mouth.
    • Remove the four (4) 7.5mm phillips screws that are inhibiting your ability to successfully remove the motor inside the mouth.
    • Remove the two (2) 7.2mm phillips screws that fasten the motor to the inside of the mouth.
  4. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 4, Bild 1 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 4, Bild 2 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 4, Bild 3 von 3
    • Use a pair of tweezers to remove the motor assembly from the mouth and inspect for any apparent issues.
    • Use a #1 Phillips Screwdriver to remove the two (2) 5.5mm phillips screws to remove the motor from the rest of the assembly.
    • Use tweezers to gently remove the motor from the rest of the assembly.
  5. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 5, Bild 1 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 5, Bild 2 von 3 Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 5, Bild 3 von 3
    • Use tweezers, inspect the main output gear for the jaw and remove if necessary.
    • Remove the four (4) 4.9mm screws from the other side of the assembly.
    • Use a spudger to gently pry apart the assembly for inspection.
  6. Zoomer Jurassic World Indominus Rex Mouth Gears Replacement: Schritt 6, Bild 1 von 1
    • Inspect the gears inside the assembly and replace any gears that have flattened or rounded teeth.
Abschluss
Luke Selby
624 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 10-3, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 648
