Einleitung
This is a guide to replace the wheels on the legs of the Zoomer Meowzies. Useful when needing to replace a broken wheel or simply for cleaning the wheels.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn the device so that the the device is on its side.
Hold the back and belly on the device and gently pull apart.
With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
Turn the Zoomer Meowzies leg to its side.
Using the Triangle driver remove the two bottom 7 mm screws.
Wheel should now be exposed. Pull wheel up and away from the rest of the leg to remove. Replace with new wheel if necessary.
