Einleitung
This guide will go step by step showing you how to get to and replace the power switch on the bottom of your Zoomer Show Pony. You will have to open up the pony's main chassis and disconnect the wires on the pony's motherboard. All of the triangle head screws in this guide are the same size, so no worries about keeping each screw separated.
Was du brauchst
Flip the pony over.
Remove the five Triangle 3 screws from underneath.
Disconnect all of the wires between the head and leg sections.
To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
Lift the switch out to replace.
